Bulk Attribute Renamer renaming column not attributes
  • June 29, 2017
  • 104 views
I am attempting what should be a simple renaming of attributes using the BulkAttributeRenamer however the results I am getting are applying the rename to column rather the attribute values.
I am using a PostGIS reader and writer. Any suggestions on what I might be doing wrong?
Best answer by jdh
The BulkAttributeRenamer renames the attributes, it does not touch the values themselves. Any of the AttributeCreator, AttributeManager, StringConcatenator transformers can be used the add a prefix to the existing value.
1000_@Value(auid)
erik_jan
Forum|alt.badge.img+26
  • June 29, 2017
You should use the StringConcatenator transformer to add "1000_" to the value.
jdh
Forum|alt.badge.img+41
  • June 29, 2017
1000_@Value(auid)
