Bulk attribute rename and sum values of duplicate attribute names
  • Aug 14, 2020 10:17 AM UTC
  • 133 views
arnovananrooij
Forum|alt.badge.img+5
Hi community,
I have a very complex challenge. I have a csv with an unknown set of (dynamic) attributes. I was asked to rename the attributes so everything from the dot is removed. That is very easy I would say with the BulkAttributeRenamer (BAR), but then I found out I get duplicate attribute names and this is not allowed in the BAR. I asked what to do with these duplicates and they said I have to sum the attributevalues if there are duplicates.
So for instance I have and attribute xxx17.1 and xxx17.2 the result must have an attribute xxx17 and the values have to be summed. This is no problem with a fixed schema, but I have a dynamic one and I have no idea how to do this. I have attached an example csv. All ideas are welcome.
Thank you.
Forum|alt.badge.img+54
  • Aug 14, 2020 11:23 AM UTC
Struggling to think of a non python solution
arnovananrooij
I have no experience with python so I hope you can find a non python solution.
  • Aug 14, 2020 11:48 AM UTC
Have you already got a method of defining the dynamic schema? I think an Attribute Exploder can probably work here
Capture
