I've been trying with FME and searching FMEPedia for several days without success.
Can I solve this old Problem comfortable with FME2013SP2 or 2012 SP3 ?
I found a few threats about this, discussed about older Versions like 2007, but without solutions working for me.
This seems to be an recurring problem over years, so I hope safe did anything in the meantime to make the workflow better.
Sources:
Line featues out of an SDE DB incl. SDE30_measures + Excel Sheet which includes ofcourse RouteIDs and Attributes for Route Event builing(Start & Endpoints).
I´ve tried to find a way with Feature Merger to join Attributes and Geometry in connection with Snipper, without getting satisfactory results.
The Workbench is running, but the results are incorrect and i have no idea why, no errors are occurring.
FME always select the correct Route, but the Snipper ist failing without an error.
The result is the complete route, no segmantation :(
Any idea ?
Thanks in advance
