Buffer area from single line
  • June 13, 2019
  • 9 views
Hi All,
I want to create a 2d or 3d buffered zone to signify an exlusion zone form utility services to allow visualize the risks while worling around them.
Any help is welcome.
Please mind that teh string line is originated by i-molel.
Kind Regards
chrisatsafe
  • June 14, 2019
Hi @sammi_ch,
If your source dataset already has the line feature that you want to create the buffer zone for, you should be able to pass it through the Bufferer (linear coordinate system - e.g. EPSG26910) or a GeographicBufferer (angular coordinate system - e.g. LL83). We have an awesome article for Buffering Features for Spatial Relation Analysis which should also be very helpful as it goes through the process of buffering and filtering.
Alternatively, if you need to build a line from a point dataset, you can first use the LineBuilder to create the line and then buffer, etc.
