British National Grid to WGS84 transformation causing shift
first step i have mapinfo tab file projected to OSGB-GPS-2015, when shown against a backdrop in ESPG:3857 a shift is noticeable and expected see below in universal translator
the ogr info for the mapinfo tab file is as below
Mapinfo:
FME reads in the following manner
FME:
there appears to be a difference in the datums being applied.
this causes the shift to remain after transformation.
have tried a number of different transformations but it would appear this shift is present on initial reading of the tab file in FME.
is there a custom transformation and datum to prevent this shift?
if so how would this be applied to a workbench?
thanks in advance for any help.
palhermans
Forum|alt.badge.img+10
  • April 17, 2019
@pk My take, the remaining shift probably means the 7-parameter transformation is too simple. At Ordnance Survey you can find a quite detailed documents for the best/official transformation: https://www.ordnancesurvey.co.uk/business-and-government/help-and-support/navigation-technology/os-net/formats-for-developers.html
A NTv2 file can be downloaded here: https://www.ordnancesurvey.co.uk/business-and-government/help-and-support/navigation-technology/os-net/ostn02-ntv2-format.html
And NTv2 may be incorporated in CsMapReprojector for You to define a custom reference system. A previous discussion: https://knowledge.safe.com/questions/3710/ntv2-transformation-using-own-data-grid.html
Might still be a shift, but at least the best available transformation has been used
  • April 18, 2019
hello palhermans,
thanks for reply. yes I've actually tried the answer you supplied and indeed the shift is still apparent.
the thing is I need it to line up correctly for the purpose of the data is to see what properties within our local authority are within a tree preservation order scheme. whilst a small shift is unlikely to return incorrect results the visual shift is too apparent for our customer to find satisfactory.
we have the same data lined up with the back drop mapping fine in Qgis.
so my thinking is if that same transformation and datum can be applied from within FME then I may have a solution.
how I do this is my question really.
Thanks again
Forum|alt.badge.img+32
  • April 18, 2019
So you are reading the data in which has the coordinate system set to OSGB-GPS-2015 and then reprojecting to ESPG:3857?
Are you using the Reprojector, or the CSMapReprojector or the EsriReprojector?
  • April 18, 2019
hello egomm,
thanks for reply yes data from the mapinfo tab file is OSGB-GPS-2015 and the reprojection is to ESPG:3857, have used both reprojector and CSmapreprojector and the GridInquest!!reprojector
thanks
  • April 18, 2019
pk wrote:
hello egomm,
thanks
And you definitely want the data stored in ESPG:3857 (Web Mercator) not in EPSG:4326 (WGS 84)?
  • April 18, 2019
hello egomm,
thanks again for reply, sorry what is actually the case is we are trying to store in EPSG:4326 but displaying in EPSG:3857
  • April 18, 2019
pk wrote:
hello egomm,
So if you store in EPSG:4326 and display in your web mapping system do you see the same shift? I think i might not trust the inspector on this one
  • April 23, 2019
Hello egomm,
sorry for the length of time to reply.
unfortunately can almost certainly rule out the data inspector as the shift is present when viewed as we expect to publish via, our mapping application.
Below is a screen of the same data, red bordered polygons lining up perfectly against the same backdrop mapping in Qgis.
So put simply the need is to replicate how Qgis handles this particular projection and datum.
the issue here that being a Local Authority in UK, this is intended for public consumption and as the failure to adhere to the boundaries as displayed as polygons could lead to prosecution as the data relates specifically to Tree Preservation Orders, therefore the accuracy is of the utmost importance.
Thanks again for efforts so far. PK
palhermans
  • April 23, 2019
pk wrote:
Hello egomm,
Hi PK, might be I am totally out here, but what software is used for the mapping application? To me it looks like a 7-parameter transformation is reapplied but should not be necessary if data are EPSG:4326 stored and appliaction ins EPSG:3857. You are certain the data have attached a correct code for the reference system?
arnold_bijlsma
Forum|alt.badge.img+14
When converting between British National Grid and WGS84, use the EsriReprojector and choose transformation number 7:
