BRepSolidBoundaryCreator and FME 2019+
  • Jul 23, 2019 9:51 AM UTC
  • 5 replies
  • 83 views
I have tried using the BREpSolidBoundaryCreator Custom Transformer that has been very kindly created by Takashi.
I'm using FME 2019 (Build 19238)
Log suggests some issues with Python libraries (see attached image).
Has anyone else come across this ???
Is this Transformer Compatible with FME 2019 ???
Any help much appreciated
Regards
Howard L'
@takashi
  • Jul 23, 2019 10:17 PM UTC
Hi @howard_l, the transformer contains some Python scripts and those should work with both Python 2.7 and Python 3.x.
In my quick test, the attached workspace containing the transformer worked fine in FME 2019.0.2 build 19260. Can you please try running this with Python 2.7 and 3.x,?
brep-solid-boundary-creator-python-compatibility.fmw (FME 2019.0.2)
  • Jul 24, 2019 9:15 AM UTC
HiYa @takashi, thanks very much for your reply.
Some observations...
I ran the workbench that you attached - same result as previously - did not work -(see screen dump and error message below).
I then copied and pasted all parts of your workbench into a brand new FME workbench, saved file (new *.fmw)
Ran new workbench file *** IT WORKS ***
Not sure exactly why this copy and paste trick works - but it does !!! (see screen dump below)
I've now updated FME 2019 to FME 2019.1 (Build 19608)
Again, your original file does not work - but a copy and pasted version runs well in Build 19608
Thanks once again for your help with this.
Regards
Howard L'
Original FMW - does not work
Elements copied and pasted to new workbench - works
  • Jul 24, 2019 10:50 AM UTC
Regards
Howard L'
Pytnon 2.7 could have been deprecated already in your FME installation. Try setting "Python 3.x+" to the Python Compatibility parameter.
  • Jul 25, 2019 7:25 AM UTC
Thanks @takashi,
*** Setting the Python Compatibility Parameter seems to have fixed the issue ***
Thanks once again - hugely appreciated
Regards
Howard L'
  • Jul 25, 2019 7:36 AM UTC
Thanks @takashi,
Hugely appreciated
Thanks once again
Regards
Howard L'
