Bonjour. je travaille sur une schematisation. J ai des surfaces qui se superposent. Comment faire pour les surfaces soint au minimum distante de X metres. ?
  • Sep 19, 2019 2:35 PM UTC
  • 37 views
Bonjour. je travaille sur une schematisation. J ai des surfaces qui se superposent. Comment faire pour les surfaces soient au minimum distantes de X metres. ?
merci d'avance
Hello. I'm working on a workflow. I have overlapping surfaces. How to make surfaces at least at least X meters apart?
Hello. I'm working on a workflow. I have overlapping surfaces. How to make the surfaces at least distant from X meters. ? thank you in advance
  • Sep 19, 2019 2:50 PM UTC
Hopefully I'm understanding your question correctly: You can use the AreaOnAreaOverlayer to clip overlapping surfaces against each other (check the _overlaps attribute).
If you want non-touching polygons you could use a Bufferer on the surface where _overlaps > 1 and clip that against the other surfaces.
