Blob field in SQL Server to usable Geometry
  • Sep 26, 2019 7:21 PM UTC
  • 6 replies
  • 261 views
Hello, I have a BLOB field, it is supposedly multiple points that form a polyline, but I cannot export the blob into a usable geometry. I have tried GeometryReplacer and GeometryExtractor but I have not been able to get usable results. I attached an excel file with the BLOBs
Best answer by david_r
The only way I was able to get the GeometryReplacer to return anything else than an error was by first removing the "0x" prefix and treat it like a QlikMaps Encoded Polyline. However the result doesn't make much sense (to me):
I think the key here is to know how the geometry is encoded in the blob, or at the very least know which software is used to manipulate it.
daveatsafe
Forum|alt.badge.img+24
  • Sep 26, 2019 8:36 PM UTC
Hi @morijlumos,
Do you know what format the BLOB geometry is in?
  • Sep 26, 2019 8:46 PM UTC
Hi @morijlumos,
It is varbinary(max)
  • Sep 26, 2019 8:48 PM UTC
Hi @morijlumos,
I am fairly certain it is supposed to be points
daveatsafe
  • Sep 26, 2019 8:55 PM UTC
From that info, it appears to be a set of points in each record, but the key thing to know is how is it binary encoded. The GeometryReplacer in FME supports several kinds of binary geometries: FME Binary (likely not the case), OGC WKB and SQL Server Binary. I have tried all those, and none of them seem to be the encoding used.
  • Sep 27, 2019 7:06 AM UTC
  • Sep 27, 2019 10:57 AM UTC
Thanks! It looks like after all that there doesn't seem to be much useable data in there at all, or its something that ESRI doesn't want to show us!
