Bigger version but smaller date
  • August 24, 2017
  • 12 replies
  • 77 views
Hello, I have the following table:
Name Version Date
Alpha 1.1 20170304
Alpha 1.1 20180304
Alpha 1.2 20150204
Alpha 1.3 20191004
Beta 1.1 20130304
Beta 1.2 20150404
Beta 1.2 20161204
Beta 1.3 20151004
I would like the following records as an output:
Alpha 1.2 20150204
Beta 1.3 20151004
These are the records who have a bigger version but theirs dates are inferior to the max date of the previous version grouped by name. How can I find these records automatically? I have more than 100 000 records to analyze. Thanks!
courtney_m
Forum|alt.badge.img+23
  • August 24, 2017
Nice brain teaser!
courtney_m
  • August 24, 2017
You can use a Sorter, then a DuplicateFilter. Set up the sorter to sort first by Name, then by Ascending date, then by descending version, as shown below:
Have that result lead into the DuplicateFilter where Key Attribute is Name, and Input is Ordered is set to Yes.
courtney_m
  • August 24, 2017
Nice brain teaser!
Okay, someone else beat me to it!
tim_wood
Forum|alt.badge.img+8
  • August 24, 2017
I believe this will do it. There may be other ways...
tim_wood
  • August 24, 2017
You may be able to replace the AttributeFilter and Testers with the TestFilter.
tim_wood
  • August 24, 2017
I've replaced the original image with a new version that has an extra AttributeManager to give the correct results.
erik_jan
Forum|alt.badge.img+26
  • August 24, 2017
This was a fun challenge and I believe it can be fairly simple:
First sort the data on Name, Version and Date.
Then create an attribute for the Name, Date and Version of the previous record.
Then test if the previous Name = the Name and the previous Date > the current Date.
The output is:
erik_jan
  • August 24, 2017
The output is:
Here is the workspace: test.fmw
  • August 25, 2017
Do you need to compare each date with the latest date in all the previous versions belonging to the same group? For example, if the date of "Alpha 1.3" was 20161004 (later than "Alpha 1.2, 20150204" but earlier than "Alpha 1.1, 20180304"), should the "Alpha 1.3" be detected?
If "No", @erik_jan's solution would work as expected.
If "Yes", the workflow should be modified like this.
tim_wood
  • August 25, 2017
I was just thinking about that same scenario. Are you just looking for one date out of sequence (e.g. 2013, 2014, 2012, 2015, 2016) or many (e.g. 2013, 2010, 2014, 2012, 2015 or 2013, 2009, 2010, 2011, 2014, 2012, 2015)?
  • August 25, 2017
The "_prev_update" indicates the maximum in the dates of all the previous versions belonging to the same Name group, regardless of the sequence of dates.
In addition, an InlineQuerier with this SQL statement could also work.
select x.*
from (select a.*, max(b.Date) as _prev_update
    from source as a
    inner join source as b on b.Name = a.Name and b.Version < a.Version
    group by a.Name, a.Version, a.Date) as x
where x.Date < x._prev_update order by x.Name, x.Version
mark2atsafe
Forum|alt.badge.img+59
  • August 25, 2017
As you tagged it, this would be perfect for the Sorter to do - if only it handled dates a bit better. That's filed as PR#20821 and I am going to link this thread to the request because it's a good example.
