Best way to go about converting 3D rvt/dwg/dgn files to Cesium 3d tiles?
  • September 17, 2021
  • 289 views
As a developer completely new to this topic, with very little understanding of how these files work, what would be best way to create a pipeline that could convert .rvt/.dwg/.dgn files (only interested in 3d data) to cesium 3d tiles?
Any learning direction is appreciated as well, since I dont know much about these files, I just have to create a workflow that could solve this issue
f.kemminje
Forum|alt.badge.img+11
Yes fme can wrire cesium 3d tiles . Go for
generate workspace (in fme desktop)
  • select reader format dgn / dwg
  • select reader dataset : select your files
  • select writer format as cesium 3d tile
  • select destination dataset
Fme will generate workbench / fmw file for you.
