Best way to generate smooth contour lines from point cloud data and preserve lakes, holes, rivers etc?
  • Feb 5, 2021 2:35 PM UTC
  • 896 views
Hi, so I have a point cloud like this:
4I would like to generate contour lines but have a smooth edge at rivers and lakes.
Currently I get results like this(where lines are made across the water and weird things) using ContourGenerator with pointcloud as input.
2 using
3
I then clip these lines away but it don't look too great,
I end up with stumps like this sticking out into the river for example.
1
How could I go about fixing this, like stopping lines to form across such large distances?
Afterwards I also run Generalizer to smooth the lines out.
Tips on this?
edit: owait where did the pictures go let me readd.
jdh
Forum|alt.badge.img+41
  • Feb 5, 2021 5:42 PM UTC
Ideally you would have the rivers/lakes as a vector layer you can use as breaklines in the contour generator.
@jatjat​  Having the lake and river lines as breaklines as suggested by @jdh​ would really help. Also, have you experimented with the ContourGenerator Surface Tolerance parameter. This should eliminate some of the contours across the lakes.
to smooth the other contours - try Generalizer with some of the Smoothing algorithms & also SherbendGeneralizer
