Best way to find a change of sign
  • July 13, 2017
  • 8 replies
  • 190 views
jdh
Forum|alt.badge.img+40
I have some ordered features that contain a value, and I need to identify the inflection points, ie the feature where the sign (+/-) of the attribute value changes compared to the previous feature
ex. features have values [2,3,1,-2,-1,1,3] the inflection points would be features 3 and 5
For added entertainment there is another attribute containing a common ID, and I need to break on that value.
erik_jan
Forum|alt.badge.img+26
  • July 13, 2017
I will give it a try:
Create a new attribute ABS with conditional value (if value = @abs(value) then Y else N).
Then create the test between the current and the previous feature (ABS = ABS(feature(-1))
That should list the changes in the Failed port of the Tester.
jdh
  • July 13, 2017
I tried using an attributeCreator with the expression ((@Value(X)>=0)==(@Value(feature[-1].X)>=0)),
But I'm not sure how to prevent the first feature from one group checking against the last feature of the previous group.
erik_jan
  • July 13, 2017
In my example I would add to the Tester:
And group = group(feauture(-1))
erik_jan
  • July 13, 2017
Let me change that to:
Or group != group(feature(-1))
That will pass the first in each group.
Forum|alt.badge.img+46
  • July 13, 2017
Might need tweaking to handle first and last features but you probably want a conditional statement with a composite test
e.g.
  • July 14, 2017
Hi @jdh, if I understood the requirement correctly, this should work as expected.
[Addition] Assume that 0 won't occur in the values sequence.
  • July 14, 2017
If 0 could occur in the sequence and 0 can be considered as a positive value, this Test Condition might work a treat.
@Evaluate((@Value(feature[-1].value)==0 ? 1 : @Value(feature[-1].value)) * (@Value(value)==0 ? 1 : @Value(value))) < 0
If you consider 0 as a negative value, replace "1" in the expression with a negative value e.g. "-1".
jdh
  • July 14, 2017
I believe we have to allow for 0 in the sequence, because the first feature has no prior feature and would use the default value of 0.   In that case it would ideally be neutral, so I think your first equation works as is.
