Batch georeferencing tiff files
  • October 24, 2017
  • 82 views
bjudes
Forum|alt.badge.img+10
I have scanned historic maps in tiff format. None of these images are georeferenced. I have the corresponding bounding boxes for all these files in shapefile. The names of both the raster sheets and the bounding box tiles match. Is there any way I can match the shapefile index with the raster and then georeference the raster tile from this?
Any help is appreciated.
Thanks
Best answer by redgeographics
You can use a BoundsExtractor to get the min and max bounding box coordinates from the shapefile, a FeatureMerger to merge this information on to the TIFF files and then a RasterGeoreferencer set to Extents mode to add the min and max coordinates as a georeference.
Forum|alt.badge.img+62
  • October 24, 2017
bjudes
  • October 25, 2017
Thanks very much, that worked a treat!! You are good.
This is gold! I've been searching high and low for how to accomplish this, and I think I finally have a chance at success- still working out the details though.
