Average coordinates as centroid of polygon
  • August 13, 2014
  • 143 views
Hello,
I know there is alredy a number of questions about centroid, but I still have problem with finding it. Thing is that centroid can be calculated as a average of coordinates. But, centroid which I am getting by using CenterOfGravity or something similar gives me different result.
Does someone knows what is going on, and how to solve it?
What is the most eficient way to calculate it give an attributes containing X,Y of centroid to my polygon (I have tens of thousands polygons, and very very much points, so I need something very quick.
  • August 14, 2014
No, centroid (center of mass, center of gravity) is not average of coordinates.
Wikipedia: Centr Of mass (http://en.wikipedia.org/wiki/Center_of_mass)
There are three transformers which replace input feature with a point.
CenterPointReplacer: Center of Bounding Box
CenterOfGravityReplacer: Center of Mass
InsidePointReplacer: Inside Point of Area
However, all of them are different from average of coordinates, so you will have to create your own data flow to calculate that, if necessary.
Takashi
Thank you, Takashi. If they and you say so. Thanks.
Aleksandar
