Automating Workflow with Multiple Shapefiles of Different Schemas
  • Sep 12, 2025 6:13 PM UTC
  • 185 views
francisco_1988
Forum|alt.badge.img+5
Hi everyone,
I'm working on an FME workflow that needs to process multiple Shapefiles. The challenge is that these files come with different schemas (different attributes, attribute names, etc.).
I’ve noticed that transformers like DuplicateFilter, AttributeExposer, DatetimeConverter, SchemaMapper... don’t handle these schema changes dynamically. That means every time a new Shapefile with a different schema is added, I have to manually update these transformers to accommodate the changes.
Is there a way to make this process more dynamic, so the workflow can adapt automatically to different input schemas without manual intervention each time?
Any tips or suggestions would be greatly appreciated!
Thanks in advance!
  • Sep 13, 2025 12:59 AM UTC
Are there any rules on the schema of source datasets - i.e. attribute naming convention according to data type, required operations, etc.?
If there are clear and strict rules, it might be possible to create a workspace to handle only datasets conforming to the rules. Otherwise, however, I think “manually update these transformers to accommodate the changes”  would be your job for now.
In the future, AI could do that - and we could lose our job 😆
  • Sep 13, 2025 1:37 AM UTC
If the destination schema is common regardless of the source dataset schema, it could be possible to create a "semi-automated" workspace.
  1. Firstly create a mapping file - describing source attribute names and corresponding destination attributes names for the source dataset.
  2. Shepefile Reader: Read a Shapefile dataset
  3. SchemaMapper (Attribute Mapping): Use the mapping file to rename source attributes to destination attributes. You can create a published user parameter linked to the Dataset (mapping file path) parameter in the SchemaMapper.
  4. AttributeExposer: Expose destination attributes.
  5. Subsequent transformers: Perform required transformation using the destination attribute names.
You will have to create the mapping file and set it to the user parameter linked to the Dataset parameter in the ShemaMapper whenever source schema has changed, but it would not be necessary to edit the workspace.
francisco_1988
Understood. But every time a shapefile passes through the flow, I'll have to manually trigger transformers like DuplicateFilter, AttributeExposer, and DatetimeConverter, right? It's not possible to define a SchemaMapper for multiple shapefiles at the same time...
  • Sep 16, 2025 3:44 AM UTC
​@francisco_1988
If all the possible source schemas are known and you can distinguish them by the value of a common attribute - such as fme_feature_type, you can create a single mapping file to define attribute mapping for all the schemas. See this article to learn more.
SchemaMapper: Conditional Attribute Mapping
