Automatically remove unused attributes?
  • Sep 2, 2021 9:55 AM UTC
  • 216 views
aron
Forum|alt.badge.img+16
Sometimes one ends up with tables that contain empty columns. Is there a way to detect if an attribute is not being used, if it is "empty", and then remove it from the table? A automatic table cleaner of sorts. This would make the management of data "creep" a lot easier.
Best answer by markatsafe
@aron​ There have been a few solutions proposed over the years. @Takashi Iijima​ 's example is still working (you have to set the Python Compatibility to Python 3.+) . Also an old one here . Hopefully that give you some ideas.
  • Sep 2, 2021 5:23 PM UTC
