AUTOCAD text to arcgis's annotation
Hello,
I am current migrating autocad text to arcgis annotation.
Apparently autocad store the text using line and point.
point - migrated using labelpoint
may I know how I can migrate text that are stored with lines?
the source is in oracle spartial database and output to enterprise geodatabase.
fmelizard
Forum|alt.badge.img+22
You could transform the lines into points....
  • May 14, 2013
using which function? I am thinking of using LabelPointReplacer
but for autocad
for different justification the text appear at different position of the line.
is there a theory behind this ?
fmelizard
If you are not too interested in the exact location you can use the center point replacer.
  • May 14, 2013
what is the exact name of the transformer?
fmelizard
You can also expose the XY justification coordinates and use that to create a point.....
  • May 14, 2013
Don't think it will work. becaue the point can be start, middle or end
left(point), middle and right justify.
fmelizard
Hi seesee,
btw why not try the labelpointreplacer on the lines?
and is justification a property used in ESRI products?
Hope this helps.
