Hello, I try to solve one problem with autocad object data reader, but Im still unsuccessful :-(
I have one DWG created in FME through Autocad object data writer and I have to open this DWG in another workspace. If I load DWG via autocad object dat reader in workbench, all features are loaded, but WITHOUT TEXT entities, which are part of the block. If I load the same DWG only in inspector, I can see all features including text entities inside block. Can somebody help me please? Why autocad object data reader in workbench is not able to read text entities of block?
I attached also some screenshots.
Thank You so much!
Lubo
