AutoCAD dwg to Shapefile expose elevation
  • Apr 9, 2019 7:22 PM UTC
  • 176 views
chris_m
Participant
I have a dwg circa 1998 that contains among other things contours and spot elevations. All of these features exis in 3d within the dwg I have confirmed this using AutoCAD viewer as well as the FME inspector. The only place I see the elevation value is in the coordinates section in FME Inspector. I would like to covert these features to a shapefile and capture the elevation as an attribute but don't know how to expose this elevation value.
Best answer by redgeographics
You can use the CoordinateExtractor to grab the coordinates of the points and store them in attributes
Forum|alt.badge.img+63
chris_m
Participant
  • Participant
  • Apr 11, 2019 7:13 PM UTC
Where in my workflow would it go also since it is a line I believe it will create a list of Z values (all identical) how do I then get that into my Elev Field in my Shape?
chris_m
Participant
  • Participant
  • Apr 11, 2019 7:14 PM UTC
Here is subset of my workflow.
chris_m
Participant
  • Participant
  • Apr 11, 2019 7:34 PM UTC
Okay i went with the ElevationExtractor as it did exactly what I needed. It also was able to show me that not all of the layers were created as 3D entities
