Hello,
Do you know why autocad_color parameter is allowed from 0 to 256 for Autodesk Autocad DWG/DWF writer but is strictely limited to 1-255 for Autodesk Autocad Map 3D Object Data writer ?
It prevents to write entities with ByLayer (256) or ByBlock (0) Color parameter in addition with OD tables
