@Value(attribute) appearing as a literal string "@Value(attribute)" instead of the dynamic value
  • Jan 23, 2024 7:22 AM UTC
  • 261 views
lak
I have a workspace that takes a spreadsheet that contains these fields:
image.pngAnd I've got that reader feeding into a FeatureReader that grabs the Source Dataset feature classes from a specified .gdb.
I would like to dynamically create a new attribute called "_description" and populate it with the values in the Feature Description column.
The values that are referenced in the Feature Description column are not exposed, but I can view the values when I click on a feature in the visual preview.
I've tried to use an AttributeCreator with the following parameters:
imageHowever the output looks like the literal string input values, instead of dynamically grabbing the values from the feature:
imageIs there another way I can achieve this?
Best answer by lak
@joepk​ and @Evie Lapalme​, unfortunately the amount of attributes are not known and are definitely greater than the 6 I posted - the screenshot of the spreadsheet above was a dummy/testing one, the real one would be a couple hundred rows, all with different combination of different values strung together for the Feature Description.
AttributeExposer would do the trick but I couldn't see a way to dynamically expose attributes, and could only see ways to expose attributes manually by typing them in, and only if the attribute name is already known. Ideally I would like AttributeExposer to be able to dynamically expose by accepting an @Value() input.
@ctredinnick​ , TCLCaller worked an absolute treat - it did exactly what I expected the output to be if AttributeCreator could somehow expose the values. However, as you mentioned it being deprecated soon, I've been looking at other more future-proof methods.
I managed to solve the issue by using PythonCaller to replicate the functionality of TCLCaller, and I modified my spreadsheet slightly just for ease of input:
imageimageAnd in the PythonCaller:
import fme
import fmeobjects
import re
def makeDescription(feature):
    #featureDesciption_Input = '$First - Test'
    featureDesciption_Input = feature.getAttribute('Feature Description')
    # split the description into a list of words and delimiters
    fdSplit = re.split('(\W)', featureDesciption_Input)
    previousValue = ""
    featureDesciption_Output = ""
    #loop through and replace the placeholder fields with the values
    for f in fdSplit:
        word = f
        # if previous value is $, then this value will be the variable name.
        if previousValue == "$":
            word = feature.getAttribute(f)
        if word != "$":
            featureDesciption_Output = featureDesciption_Output + word
        previousValue = f
    # remove empty spaces and dashes where no value - order is important
    featureDesciption_Output = featureDesciption_Output.replace(" -   - "," - ")
    # if first value is empty
    featureDesciption_Output = featureDesciption_Output.replace("  - ","")
    # if last value is empty
    feature.setAttribute('_description', featureDesciption_Output)
And I get the intended output in _description:
imageThanks everyone for the suggestions and ideas.
ctredinnick
Forum|alt.badge.img+22
  • Jan 24, 2024 1:58 AM UTC
In the past I've done this with a TCLCaller, basically telling FME to execute the @Value() function. For your _description attribute:
FME_Execute [FME_GetAttribute _description]
You'll also have to SubstringExtractor the result from 1 to -3 but it should work.
Also the TCLCaller is on the list to be deprecated for 2024. I'd be interested to know how to do this in Python.
joepk
  • Jan 24, 2024 8:09 AM UTC
If it is a finite amount of attributes (such as the 6 you posted here), I would opt for a StringReplacer, set it to Replace Regular Expression in the _description attribute and replace Regex "\\@Value\\(Name\\)" with "@Value(Name)".
evieatsafe
Forum|alt.badge.img+28
  • Jan 24, 2024 5:59 PM UTC
Hi @lak​ you mention that "The values that are referenced in the Feature Description column are not exposed, but I can view the values when I click on a feature in the visual preview." However, having these attributes exposed is a requirement for the @Value() function to pull from those attributes. You can expose these easily using an AttributeExposer. Let us know if after they are exposed if you have any luck with your workflow.
lak
  • Jan 25, 2024 12:26 AM UTC
import fme
import fmeobjects
import re
    previousValue = ""
    for f in fdSplit:
        word = f
        if word != "$":
        previousValue = f
