AttributeValueMapper imported excel - encoding is wrong
  • Mar 18, 2020 9:09 AM UTC
  • 11 replies
  • 163 views
clemensb
Forum|alt.badge.img+5
i am using an AttributeValueMapper where i import an excel file. In the preview the encoding is correct, but when i complete the import steps, the encoding gets destroyed. I dont find any option to change this. Are there options to correct this or is this not possible or is this a bug?
i am using FME(R) 2019.1.0.0 (20190710 - Build 19608 - WIN64)
Regards
Clemens
Best answer by daveatsafe
Hi @clemensb,
For a workaround, please save your Excel table to CSV, then import the CSV file into the AttributeValueMapper. The CSV reader has an Advanced parameter that lets you control the encoding of the source file, so you can force the correct encoding.
@clemensb I couldn't reproduce your issue in FME 2020 or 2019. See the attached spreadsheet, sheet2 for my example. variousencodings.xlsx
What version of FME are you using? What system locale is your machine set too.
clemensb
  • Mar 19, 2020 8:14 AM UTC
i am using FME(R) 2019.1.0.0 (20190710 - Build 19608 - WIN64) with Windows 10
the system locale is "Deutsch (Deutschland"
i got the same problem with your .xlsx, preview is fine, imported is wrong
clemensb
  • Apr 2, 2020 9:56 AM UTC
Seems like a bug for me. It is pretty bad, because now i have to check and change it by hand after the import :(
itsmatt
Forum|alt.badge.img+48
  • Apr 2, 2020 2:35 PM UTC
I was also unable to reproduce the issue - aslo German encoding on the machine. Build 19608. Could it be you are using an old version of the transformer? Have you tried adding a new one to the worksapce? or tired going through the upgrade transformer wizard?
clemensb
  • Apr 3, 2020 5:28 AM UTC
No they are uptodate and i added new one
itsmatt
  • Apr 3, 2020 1:12 PM UTC
Super strange. Reinstall? Have you tried that. Or just a new install into a completely new folder?
daveatsafe
Forum|alt.badge.img+24
  • Apr 3, 2020 5:01 PM UTC
Hi @clemensb,
clemensb
  • Apr 6, 2020 6:38 AM UTC
Hi @clemensb,
Hi @daveatsafe,
i tried now the csv-reader. Here is the opposite effect :D i tried various encodings, preview was fine, import was bad. Then i used utf-8, here is a error in the preview, but the import is fine! I will use the csv-workaround. Hopefully with the next version the excel will also work. Thank you!
clemensb
  • Apr 6, 2020 8:38 AM UTC
No but I tried it on also on other PCs in your office. There is the same problem. It might be some setting from our IT which leads to this strange behavior. So i dont think reinstalling will change this.
itsmatt
  • Apr 6, 2020 8:50 AM UTC
Does the Excel reader have the same problem when reading? That would be an interesting test.
clemensb
  • Apr 6, 2020 8:55 AM UTC
I just tested it, the Excel reader works normal. This is really strange
