AttributeValueMapper equivalent to lookup and replace in more than 1 column?
  • May 30, 2018 10:51 PM UTC
  • 149 views
davideagle
Forum|alt.badge.img+21
I've got a dataset with lots of columns and the contents of the ones I need to tackle contain many zeros (0) and lots of ones (1)... there are also lots of 'Yes' and 'No' values. I want 'selected' columns to be checked for the existence of a 0 and it should be replaced with a 'No', 1s need to be 'Yes'.
The AttributeValueMapper will do this on 1 attribute, but I don't want 1 AttributeValueMapper per column.
An AttributeManager allows me to set conditional values, but I don't want to have to create this conditional rule for every column, even with FME 2018 supporting copy\\paste, that's too much effort.
I'm currently using 2 chained NullAttributeMappers, with one of them handling the 0 mapping to No and the other the 1 mapping to Yes.
But what would you do? I'm looking for ideally a elegant single transformer solution and really an AttributeValueMapper that could work on more than just 1 column seems to be an 'Idea' I ought to submit, but have I overlooked something blindingly obvious?
Pretty sure this could be done with Regex or Python, but what about a standard transformer?
Thanks in advance...
Best answer by takashi
Hi @1spatialdave, a possible way is to use the StringCocatenator with Overwrite Existing Attributes option and the @ReplaceString function.
@ReplaceString(@ReplaceString(@CurrentAttribute(),1,Yes),0,No)
  • May 30, 2018 11:04 PM UTC
davideagle
  • Jun 5, 2018 5:14 PM UTC
Thanks @takashi, works like a dream!
