AttributeValidator - problems setting up Minimum Length Operator
Hi ,
I’m having problems configuring the ‘Minimum Length’ Operator in the AttributeValidator Transformer. Ideally, I would like it to test that the minimum length of characters is greater than 8. When I run the Translation I get the following message:
An error was encountered evaluating a TestFactory test: Illegal operator `MINIMUM_LENGTH'
supplied for test evaluation -- operator must be one of < > <= >= != = ==
I believe the issue is with my incorrect settings in ‘Rule Configuration’ column. Does anyone have a working example of how to configure the ‘Rule Configuration’ using the ‘Minimum Length’ Operator?
Many thanks
Best answer by david_r
What did you type into the rule configuration? This should be enough to check for length >= 8:
  • April 7, 2017
  • April 7, 2017
I used the Arithmetic Editor typing in the equation: @Value(Start)
length >= 8.
Using your method I still appear to be getting an error
The input is numeric, could that be a possible issue?
Many thanks :)
erik_jan
Forum|alt.badge.img+26
  • April 7, 2017
If the value is numeric you could use the test shown in the image below:
length >= 8.
Many thanks :)
Why not just type 8 into the Rule Configuration column, like shown in @david_r's screenshot?
If you intend to validate if the input is 8 or more figures (never containing non-figure), this regex might be better.
^\d{8,}$
As Takashi suggests, just type "8" and nothing more.
  • April 10, 2017
As you and Takashi suggested, simply typing 8 into the Rule Configuration column was all that was needed.
Cheers :)
