AttributeSplitter
  • Nov 24, 2018 9:04 PM UTC
  • 104 views
Hello,
I have an entrance like this.
I would like an exit like this.
How to do it ? with the transform AttributeSplitter ?
Thank you
Best answer by cwarren
Hi @lecoqgaulois,
One way to do it would be to use the AttributeSplitter on the attribute NUMEROS with a comma for the delimiter. This creates a list that you can then explode with the list exploder. Example workspace attached. Hope this helps.
example.fmw
mark2atsafe
Forum|alt.badge.img+59
I suggest an AttributeSplitter followed by a ListExploder
note: for some reason the images are now missing. I will see if I can find out what the problem is.
cwarren
  • Nov 24, 2018 9:17 PM UTC
Hi @lecoqgaulois,
example.fmw
