Attributes in Contour Line
  • Nov 22, 2017 7:45 PM UTC
  • 8 replies
  • 111 views
danilo_fme
Forum|alt.badge.img+58
I have Yellow lines with values ( attribute Value ) and i need to assign value to quotes ( red lines ), respecting the interval Value+1:
My situation:
What i want ( black numbers ):
Attached my files.
Thanks, -
Danilo
Best answer by jdh
I have two wildly different suggestions.
1. Generate a surface model from just the known contours (yellow) and drape the unknown contours (red) on the surface, get the average Z value for the contour and round to the nearest interger.
2. Use some combinations of the LeftRightSpatialCalculator and NeighborFinder. Thought is that for each known contour you check whether the nearest known contour on the Left is increasing or decreasing. Then the nearest unknown contour on the left side will be +/-1 and the opposite on the right. Wash, rinse, repeat.
jdh
Forum|alt.badge.img+41
  • Nov 22, 2017 11:00 PM UTC
Forum|alt.badge.img+63
My first suggestion would be #1 too, it would be an interpretation though, depending on how wild the terrain changes in the black contours it may or may not be correct.
danilo_fme
  • Nov 24, 2017 10:16 AM UTC
Hi @jdh, thanks your help.
The number 1 = is use the transformer SurfaceModeller ?
Thanks,
Danilo
danilo_fme
  • Nov 24, 2017 10:17 AM UTC
Thanks @redgeographics :)
danilo_fme
  • Nov 26, 2017 6:07 PM UTC
Thanks,
Danilo
@jdh and @redgeographics
hi, is ok with my Workspace above?
Thanks,Danilo
Thanks,Danilo
Yes, that should do the trick.
danilo_fme
  • Nov 27, 2017 12:39 PM UTC
Hi @redgeographics,
This process is so slow? Attached the logfile.
Thanks, - log-file.txt
Danilo
Hi @redgeographics,
Danilo
Hard to say without knowing how much data you're processing. It has to build a surface model out of the existing contours, then drape the intermediate ones over that.
