Attributes from multiple features
  • May 28, 2019 11:54 PM UTC
  • 103 views
deanhowell
Forum|alt.badge.img+24
Hello all,
I have an AutoCAD drawing that has two features on it. One is the bearing information and the other called derivation.
I am trying to create a new polygon feature that defines the bounding box of all features in the DWG that has the two labels above as attribiutes in the polygon layer.
Currently I am using a combination of bounding box accumulator and attribute creator but I just end up with three records in the output polygon layer. One that is the bounding box, one for the bearing attribute and one for the derivation attribute.
Is there a way to just end up with the one bounding box feature which has the two attributes?
diwanicka
Forum|alt.badge.img+4
  • May 29, 2019 2:53 AM UTC
@deanhowell2009 you can use a string searcher to extract the value of the bearing and derivation using this regex ([A-Z])\\w+\\:\\s\\K.*$ this will allow you to create a new attribute for each point text string. Then use pointonarea overlayer and merge attributes and choose Only Use Incoming.
