AttributeRounder Error/Warning
mel
Forum|alt.badge.img+8
When using Attribute rounder with ArcGIS 10.1 /Oracle 11 we get the following warning when we use the attribute rounder. We are generally rounding to either 0, 1, or 2 decimal places.
AttributeRounder: High-precision rounding procedure resulted in overflow; original value kept
Does anyone know how to prevent this warning and why we get it and is this something we should worry about or is it safe to ignore it?
  • March 24, 2013
this warning message is not related to either ArcGIS or Oracle, you will sometimes see this message from an AttributeRounder regardless of how you use it. The reason for this message has always been a mystery to me, as rounding a floating point number correctly should be fairly easy.
That said, I've never really had any problems ignoring this warning. However, if you think this is causing problems in your process, consider doing the rounding with a PythonCaller. Example:
def roundAttribute(feature):
    numberOfDigits = 2
    attributeToRound = "myAttributeNameHere"
    value = float(feature.getAttribute(attributeToRound))
    if value:
        feature.setAttribute(attributeToRound, round(value, numberOfDigits))
This will round the attribute named "myAttributeNameHere" to 2 digits. Modify as needed.
Hope this helps.
David
fmelizard
Forum|alt.badge.img+22
Another way to round is to make use of the round function in the expressionevaluator
  • March 25, 2013
Good call, Itay! Forgot about the ExpressionEvaluator.
Remember, though, that the Round() function alone will return an integer, i.e. you will lose all the decimals.
To round to the nearest 2 decimals, use this expression:
Round(@Value(myAttribute)*100)/100.0
Use 1000 for 3 decimals, etc.
David
