AttributeManager with Group-By function?
  • October 27, 2022
  • 12 replies
  • 2225 views
tb09114
Forum|alt.badge.img+27
I have some date with id-blocks, meaning there is a column where one and the same object is represented of several features, with different attribute values, but always with the same id for these features.
How many features there are per object varies.
I was thinking to build some 'decision-tree' in an AttributeManager to find the correct features of such an id-block to process further. Unfortunately, the AttributeManager is not a group-by transformer and I was wondering how can I group my data by id, and process the resulting group, before the next group is created and processed.
dustin
Forum|alt.badge.img+31
  • October 27, 2022
What is the process you want to do in the AttributeManager? Perhaps there is another transformer with the group by option that will perform the same process.
tb09114
  • October 27, 2022
I need to process the groups in a way like e.g.:
test if: column 1 has a value -> failed
else: get max value of column 2 and check if column 3 has no value -> passed
with the passed object:
test if: column 4 has specific value -> send feature to port 'delete'
else: send feature to port 'update/create'
dustin
  • October 27, 2022
If I'm understanding correctly, it sounds like you could use the Aggregator transformer with Group Processing set to the id-block, and the Accumulation Mode set to Merge Incoming Attributes. This should result in a single feature for each id-block containing all the columns. From there, you do your processing in the AttributeManager.
If you could upload a sample of the data, I could provide a more specific answer.
tb09114
  • October 27, 2022
Sounds interesting, crux is, all the features have all the same columns. The data structure basically looks like this
dustin
  • October 27, 2022
I see. Unfortunately, I don't think you will find a neat solution completely in the AttributeManager. I think you will need a combination of transformers that might include the StatisticsCalculator (group by id-block, to get max of column 2) and Testers/Testfilters.
tb09114
  • October 27, 2022
Yes, thats how I would to this as well, but how to keep all this 'group-specific'?
tb09114
  • October 27, 2022
I mean I have no problem using several transformers to achieve my goal... I think the best thing would be if I could build the processing with a group in mind, wrap everything in a custom transformer and send only groups in.
But I have no idea on how to get the grouping stuff done.
geomancer
Forum|alt.badge.img+60
  • October 27, 2022
Maybe you can aggregate the fetaures with a ListBuilder (group by your ID field) , and do your logic tests on the attributes in the List?
If you can provide us with some relevant sample data, and the results you want to get with those data, we may be able to help you better.
virtualcitymatt
Forum|alt.badge.img+47
Custom Tansformers ​have a GroupBy option. After creating the CustomTransformer look in the Navagator on the left from inside the transformer. In the parallel processing settings somwhere is a group by option which you can expose as a parameter. I'd probably keep parallel processing level at None. But if you really want not have to worry about the groups or lists then this could be a good option
  • October 28, 2022
@Thomas Becker​ I suspect that Aggregator (with lists) plus a PythonCaller with a short python script along the lines illustrated towards the end of this will give you what you need.
f.kemminje
Forum|alt.badge.img+11
  • October 29, 2022
Use Statistical calculator
group base on ID
choose count (check box ON)
This will give you new attribute , the features FME collected overall while grouping.
mathiku
Forum|alt.badge.img+8
  • January 26, 2023
What I usually do, and I need a group-based Attribute Manager surprisingly often, is to create a custom transformer. Enable parallel processing and group by desired feature. The other way around, in my case, would be handling the 'grouping' by conditional formatting which is too cumbersome.
