AttributeKeeper @Value or text input User Parameter
  • Oct 17, 2021 2:00 PM UTC
  • 6 replies
  • 237 views
connecter
Forum|alt.badge.img+10
Hi, I‘m stuck at a simple point. I want to make the AttributeKeeper filter from @Value or a User Parameter which is created by the AttributeCreator. Is it possible? I don't find a solution.
The goal is to get more attributes late in a row: test_2,test_4,_test_x in the AttributeKeeper from the AttributeCreator/User Parameter.
keeper
Best answer by connecter
Small Update: The new Version 2021.2 comes with a new version of the SchemaScanner. The new SchemaScanner don't reorder the columns and you can decide to keep or snip missing or NULL attributes. Cool new stuff! 😃
danilo_fme
Forum|alt.badge.img+58
  • Oct 17, 2021 3:05 PM UTC
Hi @connecter​
There is a custom transformer for your solution.
It is BulkAttributeKeeper:
KeeperResult:
Result
Thanks in Advance,
Danilo
connecter
  • Oct 17, 2021 4:16 PM UTC
Hi @connecter​
KeeperResult:
Result
Thanks in Advance,
Danilo
Hi @danilo_fme​ , thanks for your fast answer.
Sadly, it doesn't solve the problem for me :(. In that case all column names must a have common naming pattern string. In the test case above it works, but on other examples it will be better to get the exact column names in a row.
keeper_2
danilo_fme
  • Oct 17, 2021 6:16 PM UTC
keeper_2
Hi @connecter​ I updated the workspace.
connecter
  • Oct 18, 2021 6:57 AM UTC
keeper_2
Thanks again @danilo_fme​.
You don't get the same output than the input:
keeper_3A solution to keep the schema (and you don't need a AttributeExposer) will be the best solution. 😊
connecter
  • Nov 3, 2021 5:18 PM UTC
styx_a38
Forum|alt.badge.img+3
  • Apr 24, 2024 9:30 AM UTC
Hello. I have the exact same problem. I have the attributes that shall be kept stored as a string in an attribute (coming from a user parameter) and this question+answer was the closest I could find to my problem, but sadly I do not understand how the SchemaScanner Solution works. I tried it and get a list of all the attributes available. How do I change the schema to the ones from the attribute?
