AttributeExploder Truncating List Name
  • November 6, 2024
  • 52 views
maddiegiles
Forum|alt.badge.img+12
Has anyone else noticed when creating a list using the AttributeExploder it truncates the last two characters of the list name, resulting in complications when using a ListExploder downstream because the list doesn’t exist.
Using the default settings:
Default List Settings in the AttributeExploder Transfomer
 The resulting list:
List Name Is Truncated In Feature Information
This broke a workspace that was previously working. It was a niggly one to catch as the only thing that had changed was the FME version.
As a workaround, we created a user parameter which had the default value “_attr_li{}” and used that in the ListExploder which worked.
FME Form version:
FME(R) 2024.1.1.0 (20240729 - Build 24619 - WIN64)
Best answer by carlm
Yes it showed up in the 2024.2 Change Log:
https://fme.safe.com/changelog/?_change_log_platform=fme-form&_change_log_version=2021000000%2C2024020000
carlm
Forum|alt.badge.img+18
  • November 7, 2024
