Attribute Validation - Not Null
  • Mar 8, 2025 9:01 AM UTC
  • 206 views
iamprem
Forum|alt.badge.img+7
I am performing data validation of a excel source data.
I have configured multiple validations in Attribute validator.
Issue:
FME validates the not null validation and all other validations given, but what I require is if any of the attribute is null, I don't want to do any other validations.
How do I perform these in FME?
Best answer by crutledge
Hey ​@iamprem If I understand correctly this is what I meant. Does that help? I hope I understand correctly.
crutledge
Forum|alt.badge.img+55
  • Mar 8, 2025 1:23 PM UTC
Hi There, I would maybe put a tester or test filter before that and put the null evaluation statement there. Then direct the fails one way and the passes another. Hope that helps!
c.
iamprem
  • Mar 8, 2025 1:33 PM UTC
Hi ​@crutledge
I am generating a validation report, I want null values to be validated and included in report, but if the value for a attribute is null, I don't want other validations to be performed for the same attribute again.
How do I handle this scenario?
crutledge
  • Mar 8, 2025 1:43 PM UTC
