Attribute names to values in a single new attribute
  • November 17, 2017
  • 5 replies
  • 296 views
harmen_kampinga
I like to have all the attribute names as values in a new attribute.
Tried different solutions, but nothing worked so far.
Looking for some suggestions.
Maybe a simple question, but I can't get it right...
source table with attribute names:
[aaa] | [bbb] | [ccc]
1233 | 4322 | 2343
1231 | 9584 | 7123
target:
[id] | [names]
1 | aaa
2 | bbb
3 | ccc
erik_jan
Forum|alt.badge.img+18
  • November 17, 2017
Have you tried the Schema reader?
That will list all attributes.
Simply add a counter for the ID field.
harmen_kampinga
I'm using version 2016 right now... : no Schema reader transformer there. Possibly the Schema output from the Feature reader?
I already used the AttributeExploder creating a list, concatenated the list, used then the attributesplitter, and tried also the stringsearcher, but all without the desired results...
mark2atsafe
Forum|alt.badge.img+44
  • November 17, 2017
I'm 99% sure that the schema reader should be older than 2016. Check out Tools > Reader and Writer Gallery and see if it shows up there. There should be two: Schema (Any Format) and Schema (From Table). The "Any Format" one is the one to use here.
NB - it's a format, not a transformer.
  • November 17, 2017
"Schema reader" is not a transformer. Find "Schema (Any Format) Reader" in the Reader Gallery.
The schema feature from the Schema port of the FeatureReader should also be used here. Try extracting "attribute{}.name" with the ListExploder.
harmen_kampinga
that did the trick.
Already I thought that there should be something like that
Thanks @erik_jan and @takashi !
