Attribute Manger to concat fields based on conditions
  • Sep 19, 2019 4:08 PM UTC
  • 111 views
chris_m
Participant
So in my workspace I read in an Access mdb file in. Run it through two attributesplitters transformers to
split the BlockNO and LotNo fields
I the have an AttributeManager transformer setup where I try to clean up and conact the fields back together. I do this be creating 2 new attributes Block and Lot an using a condition statement to reassemble the pieces like this
However I can't format the if correctly, every case false and goes to the Else statement producing this type of output
The "." with no value after it is what I am trying to avoid.
Any help would be appreciated.
Chris M
Best answer by ebygomm
I would test for Attribute has Value rather than attribute is null
So if attribute Blk_List{1} has value concatenate the items together, otherwise just use Blk_List{0}
Forum|alt.badge.img+54
  • Sep 19, 2019 4:21 PM UTC
erik_jan
Forum|alt.badge.img+26
  • Sep 19, 2019 4:24 PM UTC
Before you do the concatenation, you can use a StringReplacer on both Block and Lot to replace (regex) .$ by nothing.
The .$ will only remove a . at the end of the string.
This should go right before the AttributeSplitter transformers.
Hope this helps.
