Attribute Editing
  • May 11, 2018 11:12 AM UTC
  • 7 replies
  • 76 views
bjudes
Forum|alt.badge.img+10
Hi
I want to edit a few thousand attributes, basically adding a number of 0's in the middle and end of a string. For example I want 2017_420590 to become 2017_420000_590000.
I think I may have to use the StringFormatter to edit the string use regexpr, I am not experienced using regexpr however.
Thanks for any help in advance.
B
  • May 11, 2018 11:17 AM UTC
I don't think you can use regular expressions in the StringFormatter. You can probably use the StringReplacer to achieve the same thing, however.
What's the rule for where and when to intruduce the zeros?
bjudes
  • May 11, 2018 11:19 AM UTC
Ah okay, sorry new to this. How would you suggest undertaking the problem?
  • May 11, 2018 11:20 AM UTC
If you can give us the rules for where and when you need to insert the zeros, that would be helpful. A couple of examples of before and after-values would also be nice.
bjudes
  • May 11, 2018 11:25 AM UTC
Okay.
I would like the attribute value 2017_420590 to become 2017_420000_590000.
So the addition of three 0's after every 8th character, next the addition of an _ after the 3 0's. Then finally 3 0's at then end of the string.
I hope this is what you are asking and makes sense, sorry can be tough to explain.
Thanks for the help.
  • May 11, 2018 11:30 AM UTC
Try the following in a StringReplacer:
Text to replace:   ^(.{8})(.*)
Replacement text:  \1000_\2000
Example:
bjudes
  • May 11, 2018 12:19 PM UTC
Example:
Perfect, thanks for the excellent and fast help. You are very good. :)
denizturan1985
Participant
I think you can use AttributeManager text editor with the following expression:
@ReplaceRegEx(@ReplaceRegEx(@Value(_creation_instance),(?<=^.{8}),_),(?<=^.{8})|(?<=0$),000)
attribute-editing.fmw
Edit: Including workspace
