Attribute Creator Not Evaluating Expression
  • Dec 13, 2018 2:54 PM UTC
  • 12 replies
  • 156 views
philipwhitten
Forum|alt.badge.img+15
I have an AttributeCreator that is meant to create a new attribute called "regDate" with the value:
@DateTimeParse(@Value(supByRegPlanDate), %Es)
The output for regDate is the string: @DateTimeParse(1543293100000, %Es)
However, I am expecting an output similar to: 20181127043140
Any suggestions why the output is showing the expression that had obtained the value from the feature, but, not created a DateTime?
erik_jan
Forum|alt.badge.img+26
  • Dec 13, 2018 2:58 PM UTC
Did you use the TextEditor?
You will probably need to use the Mathematical Editor.
Hope this helps.
Forum|alt.badge.img+54
  • Dec 13, 2018 3:05 PM UTC
Your input time is not in seconds but in milliseconds, convert to seconds before parsing. You cannot use the arithmetic editor for datetime expressions (but you will to convert to seconds!) I think you have to separate it into two statements e.g.
jdh
Forum|alt.badge.img+41
  • Dec 13, 2018 3:22 PM UTC
Use the following expression @DateTimeParse(@Evaluate(@Value(supByRegPlanDate)/1000),%Es)
philipwhitten
  • Dec 17, 2018 12:11 AM UTC
Hello egomm,
I am unable to view your example.
Phil
philipwhitten
  • Dec 17, 2018 12:26 AM UTC
Hope this helps.
I did use the String Editor, when I change to the Arithmetic Editor i get the output of <null>.
philipwhitten
  • Dec 17, 2018 12:32 AM UTC
That expression give the output of: @DateTimeParse(1543293100, %Es)
Previously I had the output of: @DateTimeParse(1543293100000, %Es)
I am still not getting the @DateTimeParse expression to evaluate.
philipwhitten
  • Dec 17, 2018 1:43 AM UTC
How do I test whether my version of FME has a licence or access to use the @DateTimeParse function?
philipwhitten
  • Dec 17, 2018 5:15 AM UTC
It did need to be two separate statements, thank you.
jdh
  • Dec 17, 2018 7:05 PM UTC
What version of FME are you using? It's working for me.
philipwhitten
  • Dec 18, 2018 8:54 PM UTC
I am using FME 2016.1
hlouie
Forum|alt.badge.img+17
  • Dec 19, 2018 6:51 PM UTC
Is this what you're looking for @DateTimeParse(@Evaluate(@div(@Value(supByRegPlanDate),1000)),%Es)
jdh
  • Dec 19, 2018 6:56 PM UTC
I don't have that version anymore, it does work in 2017 and 2018.1 though.
I'm curious, in the attributeCreator if you just entered @Evaluate(@Value(supByRegPlanDate)/1000) do you get 1543293100 or the expression as text?
Likewise of you entered @DateTimeParse(1543293100, %Es) does it give you the correct formatting or the expression again?
