Attempting to combine mulitple string replacements in attribute manager text editor
  • Feb 13, 2024 1:39 PM UTC
  • 5 replies
  • 404 views
stephen.bosse11
Participant
@ReplaceRegularExpression(@Value(DETAILS),<.+?>,,caseSensitive=FALSE), @ReplaceString(@Value(DETAILS),&qout;,",caseSensitive=TRUE)
The first expression replaces any text in details attribute that is bracketed with <> to be deleted.
the second expression replaces any instance where &qout; appears with “.
These work fine as separate transformations, however when trying to lump them into a single statement in attribute manager’s text editor the transform fails.
I’ve tried comma separating, spacing, and barring the functions, but have had no luck. Any suggestions on how to get this to run?
Thanks!
Best answer by dustin
@ReplaceRegularExpression(@ReplaceString(@Value(DETAILS),&qout;,"\"",caseSensitive=TRUE),<.+?>,,caseSensitive=FALSE)
Try this. If you want to string together multiple operations in a AttributeManager, you have to nest the operations. It won’t work by comma separating them. Also, the double quote you want to replace with will need to be escaped using \, and also placed in double quotes itself.
dustin
Forum|alt.badge.img+36
  • Feb 13, 2024 2:43 PM UTC
stephen.bosse11
Participant
Hi dustin, after running that I get this error
ERROR |AttributeManager_8: Unable to find closing bracket for function 'ReplaceRegularExpression' in '@ReplaceRegularExpression(@ReplaceString(@Value(DETAILS),&qout;,"\"",caseSensitive=TRUE),<.+?>,,caseSensitive=FALSE@ReplaceRegularExpression(@ReplaceString(@Value(DETAILS),&qout;,"\"",caseSensitive=TRUE),<.+?>,,caseSensitive=FALSE)'
dustin
  • Feb 13, 2024 4:48 PM UTC
Maybe I’m reading it wrong, but it looks like you copied the string in twice? There are two @ReplaceRegularExpressions in that error.
stephen.bosse11
Participant
And if I wanted to add a third function? for example:
@ReplaceRegularExpression(@ReplaceString(@Value(DETAILS),&quot;,"\"",caseSensitive=TRUE),@ReplaceString(@Value(DETAILS),&amp;,"\&",caseSensitive=TRUE),<.+?>,,caseSensitive=FALSE)
dustin
  • Feb 13, 2024 7:32 PM UTC
Yes, you would just keep nesting the new function into the location of @Value(DETAILS). Although in this case, you shouldn’t need the quotes and the escape \ before the ampersand (I don’t think)
@ReplaceRegularExpression(@ReplaceString(@ReplaceString(@Value(DETAILS),&amp;,"\&",caseSensitive=TRUE),&qout;,"\"",caseSensitive=TRUE),<.+?>,,caseSensitive=FALSE)
