@int function is rounding up in some cases
  • Feb 27, 2020 12:13 AM UTC
  • 9 replies
  • 279 views
jakethepainter
Forum|alt.badge.img+7
FME 2019.2 desktop user. I have some dates that have fractional seconds and I want to truncate the fractional seconds to whole seconds. In the fme help for the arithmetic editor it says the @int function converts by truncation if it is in the range of a 64 bit integer, which is exactly what I want.
Most dates I'm sending in are truncated. But ones of the type 20200220015759.999000 are getting rounded up. Which, in the case of above, is an invalid date because it rounds up to 60 seconds.
Is this a bug or am I missing something?
  • Feb 27, 2020 9:18 AM UTC
I agree that this is unexpected behavior, I was able to reproduce it as well. Even the AttributeRounder set to round down with 0 decimals gave the wrong result.
Unless someone comes up with a good workaround, consider forwarding the case to Safe support, pointing back to this thread.
Forum|alt.badge.img+54
  • Feb 27, 2020 9:35 AM UTC
Isn't this a floating point issue? The following in python returns 20200220015760.0
  • Feb 27, 2020 9:41 AM UTC
Looks like you're right:
and
  • Feb 27, 2020 9:42 AM UTC
and
Someone told me about floating point issues a while back :-)
https://knowledge.safe.com/questions/3538/attribute-rounder-0145.html
  • Feb 27, 2020 9:46 AM UTC
To avoid floating point issues, try using the StringReplacer to simply remove any decimal point and everything that follows at the end of the value:
I should definitely follow this guy... ;-)
jakethepainter
Thanks everyone. Looks like the string functions may be better for this.
mark2atsafe
Forum|alt.badge.img+59
I'll file this with the devs. I know it's expected from the computing point of view, but I'm sure we must be able to come up with a fix for this - at least in the AttributeRounder. Using a direct function might be a different matter.
mark2atsafe
So I made this my question-of-the-week.
While writing that it occurred to me that perhaps you could just use the round() function instead of int(), and then put the data through a DateTimeConverter with Repair Overflow turned on.
If you just want valid datetimes, rounded to the nearest second (up or down), that would be the way to go I think.
But if you absolutely want them rounded down/truncated, then the StringReplacer is the better solution.
