@DateTimeParse failing how do I format 20190114000000.000
  • May 17, 2019 12:18 PM UTC
  • 132 views
DateTimeConverter transformer will convert this date type 20190114000000.000
However I also have null attributes so it rejects the data on reaching the first null value.
I have tried using Attribute Manager and the @DateTimeParse function but keep getting this error
AttributeManagerIfValueDateParse: '%Y' was successfully parsed, then failed to parse '-%m-%d %H:%M:%S'
AttributeManagerIfValueDateParse: Failed to evaluate expression '@DateTimeParse(20190114000000.000,%Y-%m-%d %H:%M:%S)'. Result is set to null.
Does the function not support this date format?
Forum|alt.badge.img+54
  • May 17, 2019 12:23 PM UTC
If you are wanting an output of 2019-01-14 00:00:00 then you need to @DateTimeFormat
But you should also be able to use the DateTimeConverter and set passthrough nulls, empties or missing to Yes
I am using 2017.1 so the DatetimeConverter does not have set passthough options.
using @dateTimeformat on my output does not work
  • May 17, 2019 1:46 PM UTC
Not 100% sure if DateTimeFormat is available in 2017 (i think it should be) but the case matters here and I notice you have a DateTimeformat not DateTimeFormat. If you go into the text editor you can check what Date/Time functions are available on the left hand side
Ahh you are right!
My mistake in not typing the name correct.
Success. Thank you so much.
