At character to some lines
  • Feb 3, 2020 9:21 AM UTC
  • 54 views
remco
I need the following:
Every line has to have two numbers, the rest will be the same.
Is there a simple way to do this?
With kind regards Remco
Best answer by takashi
Alternatively, this conditional value setting could also work for you.
If @Value(input) Contains Regex ^\d\D*$
Then 0@Value(input)
Else @Value(input)
Forum|alt.badge.img+54
  • Feb 3, 2020 10:02 AM UTC
You could use a string searcher to find attributes with two numbers (search for regex \\d{2} ), you could then add the 0 at the front for any non-matches
  • Feb 3, 2020 3:51 PM UTC
Then 0@Value(input)
Else @Value(input)
