Associate Appearance to surface base on feature attribute
  • November 22, 2017
  • 52 views
Greetings FME Community!
I have a CityGML of buildings [1] and I want to attach new textures to the roof surfaces.
The Appearance should be a texture based on a specific GeoTIFF that was generated for every buildings.
Every GeoTIFF has the CityGML feature unique id as name. I don’t find a way to save every texture in the FMELibray and, mostly, retrieve the right Appearance for every feature of the CityGMLd to
I think this should be related to the AppearanceSetter [2] settings or SharedItemRetriever [3], but I can't figure how to use them properly.
Kind regards,
[1] http://donnees.ville.montreal.qc.ca/dataset/maquette-numerique-plateau-mont-royal-batiments-lod2-avec-textures
[2] https://docs.safe.com/fme/2017.1/html/FME_Desktop_Documentation/FME_Transformers/Transformers/appearancesetter.htm
[3] https://docs.safe.com/fme/2017.1/html/FME_Desktop_Documentation/FME_Transformers/Transformers/shareditemretriever.htm
Best answer by takashi
Hi @jeandenis, this workflow illustrates how you can register rasters to the FME Library, retrieve one of them according to its name (unique id), and then map it to surface features as a texture appearance.
However, depending on the scenario, this workflow could work as well.
Hope this helps.
  • November 23, 2017
Hope this helps.
  • November 23, 2017
Thank you @takashi !
The variable usage is quite insightful.
I only try the first solution because it seems much more generic than the second.
Best regards,
