I have 2 data sets (shape-files). A point dataset with 3d-points or at least points where the elevation is stored in an attribute field (different data quality) and a polyline dataset with 2d-lines whose vertices are identical to the points from the point dataset. Is there a way to assign the elevations from the point datasets to the line vertices and then create 3d polylines from them?
Thanks for your help
