Assign unique value to a set of records
  • May 31, 2018 7:28 AM UTC
  • 39 views
raaaju1990
Forum|alt.badge.img+11
I have a set of records. Im using Modulo counter to count maximum 7 records. Now, I need to assign a unique value to each set of 7 records. For example I need below output,
ABModulo_countUniquexyz1abc101xyz2abc211xyz3abc321xyz4abc431xyz5abc541xyz6abc651xyz7abc761xyz1abc102xyz2abc212xyz3abc322xyz4abc432xyz5abc542xyz6abc652xyz7abc762xyz1abc103xyz2abc213xyz3abc323xyz4abc433xyz5abc543xyz6
abc653xyz7abc763
jeroen
Forum|alt.badge.img+15
  • May 31, 2018 8:29 AM UTC
Hey @raaaju1990 you can set multiple attribute values to the Counter Name parameter as a concatenated string using the Text Editor or use the modulo_count attribuite as counter name. See below:
https://knowledge.safe.com/idea/23363/allows-select-multiple-attribute-value-for-counter.html
