Assign Log Error Message to an Attribute
  • September 21, 2017
  • 8 replies
  • 34 views
danilo_fme
Forum|alt.badge.img+45
My workspace try to writer in a Table in ArcSDE, but doens't work.
Has a way to get the error message from ArcSDE? Similar we have the ora_error for Oracle.
Thanks,
Danilo
Best answer by lenaatsafe
Hi @danilo_inovacao
would it help to scan the log (as a text file) and find all strings that contain |ERROR| ? If a transformer rejects a feature, quite often (and I hope soon always) there will be an attribute added to the feature that explains the reason of rejection. However, in your case the feature is rejected by the Writer... it wouldn't be helpful to add anything to the rejected feature in this case.
fmelizard
Forum|alt.badge.img+19
Are you getting any error messages in the log?
danilo_fme
Hi @TiaAtSafe,
Yes, this error is in the Message.
Attached the log file. log-error.txt
Thanks,
Danilo
fmelizard
Hi @danilo_inovacao, I'm seeing a unique constraint violation in your log file.
Continuing translation as directed by use of the '_CONTINUE_TRANSLATION_BAD_DATA' keyword. Feature will be lost. The error message was: "Error while executing stream insert operation for table 'ANEEL_BDGD.ARAT'.:SDE_ERROR_CODE(-51) Underlying DBMS error. SDE_EXT_ERROR(1) SDE_ERROR_MSG1(ORA-00001unique constraint (ANEEL_BDGD.ARAT_PK) violated
) SDE_EXT_ERROR_MSG2()"
Can you verify that this constraint exists and that the data you are trying to write isn't violating this? You can use a DuplicateFilter on the features prior to writing to help test this.
fmelizard
I also see you're using the Legacy format. I'd encourage you to use the GEODATABASE_SDE format instead.
danilo_fme
  • September 22, 2017
Hi @TiaAtSafe,
Thanks your reply.
About the error, how can i get the error information ?
For example:
New attribute ( error ):
error = SDE_ERROR_CODE(-51) Underlying DBMS error
Thanks,
Danilo
danilo_fme
  • September 24, 2017
Hi @TiaAtSafe,
Yes, i'm try to assign this message error an attribute, is possible?
Thanks,
Danilo
  • September 25, 2017
Hi @danilo_inovacao
danilo_fme
lenaatsafe wrote:
Hi @danilo_inovacao
Hi @LenaAtSafe,
That its possible to be a solution in my Workspace, thanks! :)
