As a rookie of FME, i have an attribute call JEAN i want to create in the attribute , two choices of values in a string to use it in QGis Attribute : JEAN string : Yes or No How can i do please ? Thanks
  • Nov 22, 2022 12:54 PM UTC
  • 5 replies
  • 72 views
Best answer by dustin
In the Navigator panel, right click User Parameters and select Manage User Parameters.
imageIn an AttributeManager or AttributeCreator, you can set the value of JEAN to $(Parameter)
dustin
Forum|alt.badge.img+36
  • Nov 22, 2022 1:02 PM UTC
  • Nov 24, 2022 7:48 AM UTC
Thanks for your answer ddbrocato !
Other question, when i export my results in a .shp
I launch QGis and in edit mode I don't have my two choices (Yes and No) appearing
Is it related to FME or QGis? Did I forget something? Thanks
Forum|alt.badge.img+63
If you inspect the shapefile with FME, do you see Yes/No in the JEAN attribute?
  • Nov 24, 2022 10:11 AM UTC
No
Okay, so then it's not related to QGis. Can you post a screenshot of your workspace and the attributes page of your output feature type?
