So I trying to run a multi criteria test on some data.
the first 2 criteria and simple column = xxxxxxxxx
The third criteria is a arithmatic query that I use in arcgis.
Here is what I though might work:
=((@Value(SWIFT_LOAD)-@Value(Permit_License_Date))<30)
I am returning no passing values and I know for a fact due to my arcgis map that there a a few hundred returns.
Any ideas? Shpould I not use the tester to peform this part?
I am very new to FME (a few weeks)
Thanks!
