AreaOnAreaOverlayer transformer : tolérance = “None” parameter
  • Apr 16, 2024 3:37 PM UTC
  • 159 views
p-chessel-vdg
Forum|alt.badge.img+4
Hello,
In FME 2023 , in the AreaOnAreaOverlayer transformer the tolérance = “None” parameter has been removed. There only option of “Automatic” or “Custom value”.
Question : if there was Tolerance = “none” in pre FME 2023 .fmw scripts, should we use Custom Value = 0 to have the same result as tolérance = none  or “Automatic”?
Thanks
Best answer by evieatsafe
Hi @p-chessel-vdg it actually looks like the ‘none’ tolerance option was removed starting in FME 2021 onwards. However, you are correct that setting the tolerance to 0 should have the same effect as ‘none’ in that the geometries must be identical to be considered equal.
evieatsafe
Forum|alt.badge.img+28
  • Apr 19, 2024 9:51 PM UTC
p-chessel-vdg
  • Apr 29, 2024 7:26 AM UTC
Ok,
Thanks Evie for your reply and confirmation
Philippe
