Are there any plans for a scene layer package (SLPK/I3S) reader?
  • Aug 5, 2021 10:27 AM UTC
  • 446 views
I want to be able to use the feature reader transformer for scene layer packages (to combine multiple files) but the format doesn't seem to be supported at the moment. Are there any plans to include this format in the future?
I have come across this request but it doesn't seem to have gained much traction:
https://community.safe.com/s/idea/0874Q000000Tku4QAC/detail
Best answer by daraghatsafe
Hi @James Singleton​ thank you for your post. At this time it doesn't look like there are plans for the i3S reader to be added to FME, if the business case is strong enough and the idea that you linked to receives enough traction the dev team will consider implementing this reader format. One thing to note is as i3s is more of a presentation format it may be better to read in the source data into FME using a different if possible.
Hope this helps answer your question :)
daraghatsafe
Good to know, thanks!
myadegaryiutac
Forum|alt.badge.img+11
HI ​@daraghatsafe
I just wondering if we still need to wait to have a feature to read the SLPK format in FME.
As using 3D data packages are incredibly increasing to be used in analysis in the market, that would be great if the FME users can have this opportunity to use such a feature in FME as well.
