ArcGISAttachmentConnector error: The page was not displayed because the request entity is too large.
  • Oct 19, 2025 10:27 PM UTC
  • 14 replies
  • 323 views
brandonguo
Forum|alt.badge.img+7
I got this error when trying to add attachments to AGO: The ArcGIS REST API returned an error: HTTP Error Code: 413 : '' Message Code . Further details: 'The page was not displayed because the request entity is too large.'
Esri community has a solution to edit the header, but there’s no option to edit header on transformer?
Best answer by desiree_at_safe
As an update, the issue for the ArcGISAttachmentConnector: Support Upload/Update with large files has been delivered! (FMEENGINE-88567)
Please update your Esri ArcGIS Connector - safe.esri-agol to version v3.25.1 - Minimum Build FME 24187 or higher
Here is the direct link to the FME Hub: https://hub.safe.com/publishers/safe/packages/esri-agol
Thank you for your patience 🙂
j.botterill
Forum|alt.badge.img+69
  • Oct 20, 2025 7:23 AM UTC
desiree_at_safe
Forum|alt.badge.img+24
Hi ​@brandonguo!
I haven't run into this issue with the ArcGISAttachmentConnector before, but the 413 error and workaround you mentioned (editing headers) is interesting and could point to a potential improvement or fix we need to make, as ​@j.botterill mentioned.
To help us dig into this further, would you be willing to share:
  • A log file with log debug on (which gives us information about your FME version and translation process)
  • A sample workspace, screenshots, or simply file that causes this issue
This should give us a clearer picture of the best approach going forward 🙂Alternatively, you can also submit a support case with us if you rather not share your process here:
brandonguo
  • Oct 30, 2025 5:42 AM UTC
Hi ​@desiree_at_safe
See the workbench screenshot below, and part of the log file, hopefully it’s helpful.
2025-10-27 14:31:32|  36.3|  0.0|WARN  |DEBUG: urllib3.connectionpool https://services-ap1.arcgis.com:443 "POST /***********/arcgis/rest/services/PlansDrawings_***********/FeatureServer/0/584/addAttachment?f=json&token=***********-*********** HTTP/1.1" 413 67
2025-10-27 14:31:32|  36.3|  0.0|WARN  |Connection Storage: Current time: 1761535892, Expiry time: 1761537321
2025-10-27 14:31:32|  36.3|  0.0|WARN  |DEBUG: http.client send: b'POST /***********/arcgis/rest/services/PlansDrawings_***********/FeatureServer/0/618/addAttachment?f=json&token=***********-***********- HTTP/1.1\r\nHost: services-ap1.arcgis.com\r\nUser-Agent: FME/2024.7.51.24801 python-requests/2.32.3\r\nAccept-Encoding: gzip, deflate\r\nAccept: */*\r\nConnection: keep-alive\r\nContent-Length: 22958965\r\nContent-Type: multipart/form-data; boundary=7da8558c2e3d576c285146589400030c\r\nAuthorization: Bearer ***********-NIvJEb-***********\r\n\r\n'
2025-10-27 14:31:33|  36.5|  0.2|WARN  |DEBUG: http.client send: b'--7da8558c2e3d576c285146589400030c\r\nContent-Disposition: form-data; name="f"\r\n\r\njson\r\n--7da8558c2e3d576c285146589400030c\r\nContent-Disposition: form-data; name="attachment"; filename="***.pdf"\r\nContent-Type: application/pdf\r\n\r\n%PDF-1.7\********************
2025-10-27 14:31:34|  36.6|  0.1|WARN  |DEBUG: http.client reply: 'HTTP/1.1 413 Request Entity Too Large\r\n'
2025-10-27 14:31:34|  36.6|  0.0|WARN  |DEBUG: http.client header: Date: Mon, 27 Oct 2025 03:31:34 GMT
2025-10-27 14:31:34|  36.6|  0.0|WARN  |DEBUG: http.client header: Content-Type: text/html
2025-10-27 14:31:34|  36.6|  0.0|WARN  |DEBUG: http.client header: Content-Length: 67
2025-10-27 14:31:34|  36.6|  0.0|WARN  |DEBUG: http.client header: Connection: keep-alive
2025-10-27 14:31:34|  36.6|  0.0|WARN  |DEBUG: http.client header: Vary: X-Esri-Authorization
2025-10-27 14:31:34|  36.6|  0.0|WARN  |DEBUG: http.client header: Request-Context: appId=cid-v1:1bba6b68-99a2-4fc8-af9d-affe0c423ee5
2025-10-27 14:31:34|  36.6|  0.0|WARN  |DEBUG: http.client header: x-arcgis-upstream: ap1h00c00
2025-10-27 14:31:34|  36.6|  0.0|WARN  |DEBUG: http.client header: Strict-Transport-Security: max-age=63072000
2025-10-27 14:31:34|  36.7|  0.1|WARN  |DEBUG: http.client header: X-ArcGIS-Correlation-Id: 238dc17fc59ccea3
2025-10-27 14:31:34|  36.7|  0.0|WARN  |DEBUG: http.client header: X-ArcGIS-Instance: ***********
2025-10-27 14:31:34|  36.7|  0.0|WARN  |DEBUG: http.client header: Access-Control-Allow-Origin: *
2025-10-27 14:31:34|  36.7|  0.0|WARN  |DEBUG: http.client header: Access-Control-Allow-Headers: Content-Type, Authorization, X-Esri-Authorization
2025-10-27 14:31:34|  36.7|  0.0|WARN  |DEBUG: http.client header: Access-Control-Allow-Credentials: true
2025-10-27 14:31:34|  36.7|  0.0|WARN  |DEBUG: http.client header: x-azure-ref: ***********-r1b5d8b8bc6vj569hC1MELpv1c00000005z0000000005231
2025-10-27 14:31:34|  36.7|  0.0|WARN  |DEBUG: http.client header: X-Cache: CONFIG_NOCACHE
salvaleonrp
Forum|alt.badge.img+23
  • Oct 31, 2025 6:53 PM UTC
Note that there is a 2GB limit through a multi-part upload using the REST API which is what the  AddAttachmentConnector uses. Do you know the file sizes of your attachments?
https://support.esri.com/en-us/knowledge-base/how-to-add-large-attachments-to-a-feature-using-the-arc-000029873
desiree_at_safe
Hi ​@brandonguo!
I was able to reproduce your issue with a 29.3 MB PDF. It seems large images can trigger a similar error, though it’s not exactly the same one.
Regarding the workaround, while I haven’t tested the “edit header” method you mentioned (which I believe was discussed in an Esri Community thread), you could theoretically construct the REST API call in the HTTPCaller and edit or specify that header there:
Could you share the exact thread you’re referring to so I can confirm?
It also looks like there are a few other potential workarounds mentioned in this Esri Documentation on how to Attach files larger than 10 MB , such as compressing the file or uploading it to ArcGIS Online and attaching a link instead.
Either way, it does look like this is a great candidate for product improvement IDEA. I’d encourage you to Submit an Idea Here. Other FME Community users can upvote it, and our product team reviews these for future inclusion in FME. 🙂
desiree_at_safe
Thank you for sharing that doc ​@salvaleonrp! It’s possible we might be using an older version of this REST API
I’ve created a case for the team to investigate this further!
[INTERNAL REF: FMEENGINE-88567]
mgg_beca
Forum|alt.badge.img+20
  • Nov 9, 2025 10:43 PM UTC
I have struck the same error. In my case I cannot upload any pdf files larger than 10mb, so I wonder if the multi-part uploading is not working correctly.
brandonguo
  • Nov 9, 2025 10:50 PM UTC
brandonguo
  • Nov 9, 2025 10:52 PM UTC
​@mgg_beca Try using httpcaller, it solved most of the file upload issues with ArcGISAttachmentConnector. Though I still have few failed uploads left.
mgg_beca
  • Nov 9, 2025 10:53 PM UTC
Hi Brandon,
I am still get ting the same error with httpcaller, did you have to add any additional headers or workarounds?
This is not working for me
brandonguo
  • Nov 9, 2025 10:59 PM UTC
​@mgg_beca
My setup, this solved half of the failed attachments by ArcGISAttachmentConnector. Still, not perfect solution.
mgg_beca
  • Nov 10, 2025 12:51 AM UTC
 I ended up just using an output from fme as a match table and doing it in ArcGIS Pro. worked fine.
salvaleonrp
  • Nov 10, 2025 11:28 AM UTC
I wonder if you hae the right mime-type for a PDF file.
Check this out:
​@mgg_beca the mime-type for a pdf is: application/pdf. This is not in the drop down but you can type it.
desiree_at_safe
