Approach to creating a 3D Concave Hull with volume?
  • May 1, 2014 7:29 PM UTC
  • 75 views
makt
The output of HullAccumulator is 3D but it is a suface. I'm looking for ideas to how to use the HullAccumulator along with other transformers (or some other approach completely) to define a volume all around 3D points, lines, or areas.  I would like to produce "true 3D" volume rather than 2.5D.
gio
Forum|alt.badge.img+15
  • May 2, 2014 2:06 PM UTC
aifk FME hullaccumulator is a 2D transforer
You can always define a volume with fme when using sufficient math. (now how do i get the faces on this Elipsoid?)
But you can only create TIN's in FME using fme.
No smooth surfaces here. The closest u can get is draping with a decent tolerance.
But when u export the draped polygons to like autocad u just get the draped lines, no surface.
I have not find a way to do that using FME anyway..
It's not a 3D modeller.
